| Application | PLAXIS 3D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 3D 2013.00 |
| Found in Version | PLAXIS 3D 2013.00 |
| Fixed and Released in Version | PLAXIS 3D AE.02 |
| Issue # | 19624 |
| Date created | 13 March 2015 |
A flow calculation may be used to lower the water level around an excavation. In some cases it may happen that although the water level is lowered beneath the bottom of the excavation still external water loads are (partly) visualized inside the excavation. This may give the impression that there is still water inside the excavation whereas actually there is not. Also see the example graph below.
This has been resolved in PLAXIS 3D AE.02.
In PLAXIS 3D AE.00/3D AE.01, we made improvements for the visualization of the external waterloads, but this problem may still happen for some rare cases for these versions.
To be able to examine if indeed the water loads are incorrectly visualised you may for example:
