| Version: | CONNECT Edition | ||
| Area: | Measure | ||
| Subarea: | N\A |
For 2 complex shapes or surfaces I need to determine the volume enclosed between the 2.
1. Use the loft surface tool create a surface between the 2 surfaces of interest. Enable the keep profiles options for subsequent steps
2. Use the Stitch Surfaces Tool to create a closed volume of the 2 initial surfaces and the created surface from Step 1.
3. Determine the Volume using either the Measure Volume tool or check the properties Dialog
Surface Between Volume Calculated (Forum)
| Original Author: | David Trejo-Rodriguez |
