| Version(s): | MCE, 2023, 2024 | ||
| Area: | Other | ||
| Subarea: | N\A |
Generate Type 7 Minidump with Page Heap
How to create and collect Type 7 Minidump with Page Heap
To trouble shoot Managed Exception from .NET and Heap corruptions, we would require a Type 7 (Full Dump) with Page Heap.
The methods here below allow MicroStation to generate a more comprehensive minidump file that can help Bentley Technical Support to identify the causes of a crash.
For MCE, MS2023, MS2024 use the following reg files.
For MicroStation V8i use the following reg files.
How to quickly find and collect Exception logs and Minidump files
Generate Type 7 Minidump files
Enable page heap
