| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 24 April 2013 |
| Date modified | 24 April 2013 |
The material type setting Drained, Undrained A and Undrained B refers to a plastic, dynamics and phi/c reduction analysis. In consolidation analysis the material type is ignored for the types Drained, Undrained A and Undrained B, and the actual specified permeabilities are used. Therefore a "drained" material set can show excess pore pressures during or at the end of a consolidation phase.
