Product: | MicroStation | ||
Version: | V8i, CONNECT | ||
Environment: | N\A | ||
Area: | DWG | ||
Subarea: | Open |
How to disable the creation of backup files (.bak) when a DWG file is opened in MicroStation.
When MS_NO_DWG_BACKUP is set to 1 the backup files will NOT be created when a DWG or DXF file is opened or editted.
Original Author: | Bentley Technical Support Group |
