| Version(s): | V8i, CONNECT | ||
| Area: | Selection | ||
| Subarea: | Sets | ||
| Original Author: | Jonna Laitinen, Bentley Technical Support Group | ||
Need to Select all elements in design file by Color using Key-in rather than with the dialog.
Product: MicroStation
Version: V8i, CONNECT
Area: Selection Set, Search By Element Attributes
Open the Utilities - Key-in menu. Type in:
mdl load selectby
selectby color on
selectby color {color number}
selectby execute
For example "selectby color 3" will select all the elements of color 3.
