Product: | MicroStation | |
Version: | CONNECT Edition | |
Feature: | Productivity |
The Situation |
Would you like to become a more proficient and productive MicroStation User? |
Solution |
Through the “Learning Tips” you will learn productivity enhancing tips & tricks, enabling you to increase your product knowledge and enhance your experience using MicroStation and other Bentley software. |
Links |
• YouTube |
I have some great news to share! The new MicroStation Learning Tips Wiki page is now starting to host Learning Tips content.
We at Bentley believe in being a life-long learner. Whether you are a brand-new User, or someone that has been using Bentley software for years, there is always something new to learn.
Through the “Learning Tips”, you will learn productivity enhancing tips & tricks, covering a wide range of features and tools found in MicroStation. The tips are meant to help you boost productivity, increase product awareness, and improve your overall software experience by becoming a more knowledgeable User.
Many of the tips featured here will also work in other Bentley products such as OpenRoads Designer and OpenBuildings Designer.
Each Learning Tip will feature:
Also, some Learning Tips will contain additional information directly in the tip such as instructions on how to perform the operation(s) described within the tip.
Discover how to get the most out of MicroStation with this series of insightful MicroStation Tips & Tricks.
New Learning Tips will be added frequently, so check back often!
