| Product: | MicroStation | |
| Version: | CONNECT Edition | |
| Feature: | User Interface |
| The Situation |
| Have you ever needed to review a coordinate for an element in your design? |
| Solution |
Display Running Coordinates on the status bar. It is often necessary to verify the coordinate of a location in your design. This can be done using a tentative snap, but the tentative point mode may not be set correctly. A simple solution is to enable the display of display Running Coordinates on the status bar. |
| Links |
| • YouTube • MicroStation Help |
To enable Running Coordinates, do the following:
The coordinates from the current GCS are now displayed on the status bar.
