| Version(s): | CONNECT, 2023 | ||
| Area: | Installation | ||
| Subarea: | General |
1. Open a web browser and navigate to https://softwaredownloads.bentley.com
2. Select MicroStation product
3. Run a search using the following filter in order to access language packs for a specific language:
Major Version: -Select-
Version: -Select-
Language: Spanish for example
Architecture: -Select-
Deliverable type: Language Pack
Select the appropriate Language Pack version according to the listed Dependencies. For example, if you have installed Microstation 2023 version 23.00.02.71, you need to install the same language pack version (23.00.02.71).
4. Once the installation file is downloaded, ensure that the specified version of MicroStation is already installed and then run the Language Pack .exe file to install the Language Pack
Spanish Language Pack (Setup_MicroStationx64_10.00.00.025_es_LangPack.exe)
During the MicroStation CONNECT Edition language pack installation process, language packs for CONNECTION Client and DGN Indexer are also installed.
However, when the MicroStation language pack is uninstalled, the CONNECTION Client and DGN Indexer language packs remain installed.
This may cause error messages for users who subsequently try to reinstall MicroStation.
For this reason, we strongly recommend manually uninstalling the CONNECTION Client and DGN Indexer language packs along with the MicroStation language pack before attempting another install.
We plan to have a solution in place for the Q4 update to avoid this inconvenience.
Note: Users should select the View installed updates page in the Programs and Features section of the Control Panel to uninstall the MicroStation and CONNECTION Client language packs.
http://communities.bentley.com/products/microstation/w/microstation__wiki/23777.microstation-connect-10-00-00-25-will-not-install
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0109927
| Original Author: | Maria Munoz |
