| Version: | All versions | ||
| Area: | Cells | ||
| Subarea: | General |
Cells are appearing as a box when placing and as a phantom image when moving.
Turn OFF Fast Cells within the View Attributes dialog
When grouping elements with Group Tool or CTRL+G keyboard shortcut, the elements turn into a box
