| Product: | MicroStation | |
| Version: | V8i, CONNECT | |
| Environment: | N\A | |
| Area: | Configuration | |
| Subarea: | Workspaces | |
How can I automatically Save Settings on exit while using MicroStation?
From MicroStation's main interface, follow these steps:
- Go to File > Settings > User > Preferences
- Go to the Operation Category
- Check on option "Save Settings on Exit" & press OK
- Manually select Save Settings in the Backstage View
- Close MicroStation completely, and then reopen. This will ensure the changes to the user preferences are kept.
See also
Auto Save and Auto Save Settings
Other language sources
| Original Author: | Bentley Technical Support Group | |
