| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Driver/PDF | |
Problem:
A MVBA is searching for a certain Tag in the design file. The value (in this case 05) of this Tag is saved in the variable PLOT_INDEX. The value of the variable should replace the placeholder ## of the sheet model name when creating a pdf file.
Variable Plot_Index with value 05
Name of the model with placeholder ##
The following named expression can be used to get the desired result.
System.String.Substring (PrintDefinition.MasterModelName, 0, 11) &
ConfigVar.GetExpandedConfigVar ("PLOT_INDEX") & System.String.Substring
(PrintDefinition.MasterModelName, 13, -1)
Insert the name of the named expression PLOT_INDEX in the pdf printer driver configuration file.
The PDf file name result looks like this. The placeholder ## was replaced by the value of the variable PLOT_INDEX
This named expression only works in the context of the print dialog box
You will find a detailed description - How to create a named expression -
here
VBA to extract the Tag value and update Configuration variable "PLOT_INDEX" value.
See also
Other language sources
| | Original Author: | Frank Reimann | |
