| Version: | V8,XM, V8i, CONNECT | ||
| Area: | Configuration | ||
| Subarea: | Workspace |
MicroStation Manager and other file open dialogs look different and more like windows dialogs.
Starting with MicroStation V8 XM Edition...
By default most of the file dialogs are using a "Windows" style dialog.
This can be disabled in the Preferences:
1. From Menubar, go to Workspace > Preferences [Preferences dialog opens]
2. Go to the "Look and Feel" category.
3. Disable "Use Windows File Open Dialogs".
Note: While using Windows open dialog, it is possible to temporary switch the MicroStation style dialogs, by holding SHIFT and pressing ESC.
