Tips and tricks for easier drawing
Application
PLAXIS 3D
Version
PLAXIS 3D
Date created
09 May 2011
Date modified
09 May 2011
This movie shows three methods to construct the three surfaces of an excavation.
Drawing with vertical movement and snapping.
Using movement limitation planes.
Using extrude, decompose and delete.
