| | Product(s): | MicroStation | |
| | Version(s): | N\A | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | N\A | |
When using a printing queue with a long printer queue name, MicroStation gives the following error message in a Command window:
Windows plot subclass-check failed, code 3419
Make sure to create a printer queue, whose name is less than 30 characters
| | Original Author: | Frank Reimann | |
