| Version(s): | V8i & CONNECT | ||
| Area: | Printing | ||
| Subarea: | Print Def/Raster |
Bad print quality when Rasterized is ON
1. Check and see that you have set the File > Print > File > Edit Print Configuration file > Base properties > Raster Printing > Raster Quality Factor = 100%.
2. Also make sure that you have File > Print > Settings > Raster Options > Raster Quality Factor = 100% and check and see that Printer Resolution is set to min 600 DPI.
http://communities.bentley.com/products/microstation/microstation_printing/w/wiki/14299.what-is-the-difference-in-the-raster-quality-factor-setting-and-the-rasterized-quality-factor-setting
| Original Author: | Anders OMahony |
