| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
Can you apply two Default Print Styles and if so how are they applied?
If you have more than one default print style, they will be applied alphabetically. Mutually exclusive properties that appear in subsequent default print styles override the same properties that appear in previous default print styles.
