Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | |||
Subarea: | N\A | ||
Original Author: | Johnny Kendall, Bentley Technical Support Group | ||
Getting white space when printing to a HP DesignJet T7100 using the printer.pltcfg plot configuration file.
Plotting to Arch E 36x48 paper size. The actual plot size is 35.5 x 41.25.
Select the Windows printer for the HP DesignJet T7100 and select Printer Properties.
Then select the "Advanced" tab.
Then select "Printing Defaults"
Select the Features tab.
Make sure the "Remove top/bottom blank areas" is selected.
Also do the same in Printing Preferences for the Windows printer.
Select the Windows printer for the HP DesignJet T7100 and select Printing Preferences.
Select the Features tab and make sure the "Remove top/bottom blank
areas" is selected.
