| Version(s): | 08.09.04.88 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to use text substitution in a MicroStation pen table to produce only the filename with no extension.
From the Print menu, choose Pen Table>Edit>Text Substitution and use the following syntax:
Actual: any-text
Replacement: $(basename(_DGNFILE))
