| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
User would like to create hpgl2 plotfiles without an extension. Editing plotdriver file and blanking out the extension is giving the user a .000 extension. Is there a way to leave the extension blank?
The 000 is the system-provided default in the event the printer driver configuration file does not provide one. It is not possible to create plot output files without extensions.
