PLAXIS 2D/3D LE and PLAXIS DESIGNER are sophisticated applications which can operate using one or more licenses that unlock various capabilities.
When PLAXIS LE is launched, the application will present a message dialogue that will report which licenses will be used in the session.
If any of the capabilities you require is locked with a license not displayed in the message box or there are licenses displayed that will unlock features that are not required, then the licenses that PLAXIS LE will use can be redefined by selecting those that are required by clicking on the Configure Licenses button.
If you do not see this message at start up, please start PLAXIS LE, and start a new project. Then, go to the Help menu and select the license configurator.
For more information on Product Activation see here PLAXIS LE Product activation
Note that it is possible to use PLAXIS LE when not connected to the internet by reserving a license. More details can be found here: Reserving a License.
