| Version: | CONNECT | ||
| Area: | Printing | ||
| Subarea: | Dialog |
Print Organizer is not showing Print Style column. This was available in earlier V8 versions.
Print Style Column in Print Organizer will be available only in Variable Print Definition Mode.
You can set it in configuration:
MS_PLT_ENABLE_VARIABLE_DEFINITION_MODE = 1
__
You can also set it from print Organizer preferences.
| Original Author: | Klaudia Piekielniak |
