| Version(s): | N\A | ||
| Area: | |||
| Subarea: | N\A | ||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
Text elements always display and print over other elements in a file
In Workspace Preferences View Options check the settings for Anti-alias Lines and Anti-alias Text and turn them both off.
One side effect of the Anti-alias Text setting is that it always puts the text on top of other graphic elements.
