| Version(s): | 08.11.07.443 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When placing line strings to create a shape, the corners of the shape are rounded rather than square when printed.
In the .pltcfg set Default Line Cap = square, Default Line Join = Triangle, and Max Miter Angle = 45. Reload the Driver after making the change.
