| Version: | CONNECT, 2023 | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw |
The Coordinate System Rotation setting in the AccuDraw Settings keeps reverting to Auxiliary even though it has been changed manually.
Now most times when AccuDraw is used in a workflow, the Rotation setting must be manually set to the desired option.
Toggle OFF the ACS Plane Lock (Drawing Aids Tab > Locks Ribbon Group > ACS Plane Lock) and then manually change the Rotation setting.
Be sure to Save Settings (CTRL+f). If still having issues, try reloading the current file with key-in rd=.
If problem still persists in a specific file, then try the ff= key-in to fence out the file's contents and leave bad data behind.
Rotating the AccuDraw compass with ACS
Rotate an element to Screen/View Window X axis
Active depth changes after each time an element is placed
| Original Author: | Jayson Perry |
