| | Product: | MicroStation, MicroStation PowerDraft | |
| | Version: | 08.09.xx.xx and above | |
| | Environment: | N\A | |
| | Area: | Administration | |
| | Subarea: | N\A | |
How to restore MicroStation to its factory defaults
In some rare occasions, such as after a workstation power failure or an application crash, MicroStation can refuse to start up correctly, either crashing or showing an error on file open (e.g. "unable to load/create dialog item of type 'iconcmd', id = xx"). In these cases resetting MicroStation to its factory defaults can resolve the issue.
Option 1: From Windows' Run or Search command
- From Windows "Start" Button, click on your right mouse button, and then select "Run"
- Browse to ustation.exe (Default location for V8i: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exe)
Browse to microstation.exe (Default location for MicroStation Connect: C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe) - Place a space after the exe and type:
eg. ...\ustation.exe" and type -restoredefaults
...\microstation.exe" and type -restoredefaults
NOTE: the ustation.exe full path is in quotes. Place a space AFTER the quotes, then type -restoredefaults. A MicroStation command window will open displaying the details of the operation. - Press any key to Exit.
Option 2: As a command line switch within the application shortcut
- Right-click on the MicroStation shortcut icon and choose Properties
- Go to the Shortcut tab
- Place -restoredefaults after the current line in the Target field (...\ustation.exe" -restoredefaults, ...\microstation.exe" -restoredefaults) (note the space between the end quotes and -restoredefaults).
- Press Apply and Ok
- Run MicroStation from this shortcut
- A MicroStation command window will open displaying the details of the operation
- Go back in to MicroStation shortcut properties, and remove the space and -restoredefaults from the end of the file path
Option 3: From the MS-DOS Prompt Command Line
- From Explorer, browse to MicroStation folder (Default location V8i: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\, Default location Connect: C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\)
- Right-Click the folder "MicroStation" then Select the option "Open MS-DOS Prompt"
- The Command Window will open
- Type in: ustation -restoredefaults, microstation -restoredefaults
- Type "exit" to exit the command prompt.
Note: To run the Restore command silently with no User intervention, replace " -restoredefaults"
with " -restoredefaultsquiet" (Minus the quotes).
If you have custom configuration that you have added to your environment through the Manage Configuration tool,
click here: New in MicroStation CONNECT Edition Update 17 – Manage Configuration - MicroStation Blog - MicroStation - Bentley Communities, these will first need to be backed up.
To do this find these two files in this location C:\Users\[User Name]\AppData\Local\Bentley\MicroStation\10.0.0\prefs\
cache.ucf
configuration.xml
Copy these files out to separate location on your machine. These files store the workspace information stored in workspace environment.
Video:
See also:
How to Back Up and Restore User Preferences
Other Language Sources:
Français
Español
Deutsch
Italiano
| | Original Author: | Marco Salino | |
