| | Product(s): | MicroStation | |
| | Version(s): | V8i, CONNECT, 2023 | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Driver/PDF | |
How can I print a border comment in my print output files?
Option 1 - Print Dialog Print Attributes
From Microstation's Print dialog (File > Print > Print) go to Settings > Print Attributes
Turn on Print border and add the comments in the Border comment field box
This setting is only saved for the current session of MicroStation.
Option 2 - Edit the PLTCFG file
1. File> Print > Print
2. File > Edit Printer Driver Configuration
3. Under Base Properties Tab > Expand the Print Border section
4. Border On = True
5. Enter text in the Border Comment field. Here, you have the ability to automate the border comment by pulling the value of a known variable.
6. File > Save and then exit the Printer Driver Configuration dialog
7. Back in Print dialog, File > Reload Printer Driver Configuration
*Important Note: Border comments are not displayed in the Print Preview as they are just output on the printed file
Other Languages Sources
Español
Deutsch
| | Original Author: | Maria Munoz | |
