Product: | MicroStation | ||
Version: | V8, XM, V8i, CONNECT, 2023 | ||
Environment: | N\A | ||
Area: | Levels | ||
Subarea: | Level Manager |
Cannot change Bylevel Scale and/or Override Scale in Level Manager
MS_LEVEL_EDIT_ATTRIBUTE_LIST is set to exclude editing of Bylevel Style
and/or Override Style.
Bylevel/Override Linestyle scale is an attribute of the level and is considered part of the style data. If MS_LEVEL_EDIT_ATTRIBUTE_LIST does not = BylevelStyle, OverrideStyle, BylevelSymbology or OverrideSymbology, the style scale will not be able to be changed.
Set MS_LEVEL_EDIT_ATTRIBUTE_LIST = "BylevelStyle" and/or "OverrideStyle"
(or BylevelSymbology and/or OverrideSymbology).
Original Author: | Bentley Technical Support |
