Working from home with PLAXIS
In the challenging times in which COVID-19 imposed significant disruptions to day-to-day activities and affected the normal business flow of our much-valued users and employees, we at Bentley are mindfully committed to ensuring a smooth transition of work from the office to any remote location or home. Our innovative software and services are all geared for working from home or remote locations and do not impose the need to be in an office set-up.
For a general overview of how this works for Bentley products, refer to
To ensure a smooth transition of work and effectiveness of your daily workflows with PLAXIS, we have assembled information that you can refer to while working remotely or from home. We are working hard to deliver high levels of customer service, and welcome feedback, questions, and ideas on how we can serve you better in a remote work environment.
See here for a video showing you the steps to get started quickly.
This document applies to the PLAXIS 2D/3D/Monopile Designer versions.
For information on older legacy PLAXIS versions using CodeMeter licenses (PLAXIS 2D 2019 or earlier, PLAXIS 3D 218 or earlier), please read here.
Home installation
You may decide to install the software on your home computer. If you do this, once signed in via the CONNECTION Client using your normal work email login, you will have the same licenses available as you do in the office.
Machine requirements
There are several options to work remotely. You may decide to install the software on your home computer. See these minimum machine requirements for:
Downloading software
All Bentley software is downloadable via the Bentley Software Downloads pages: https://softwaredownloads.bentley.com/
Direct download links
PLAXIS 2D CONNECT Edition V20 PLAXIS 3D CONNECT Edition V20 PLAXIS MoDeTo Dowload
PLAXIS 2D
PLAXIS 3D
PLAXIS Monopile Designer
General download and installation directions are available here.
Accessing Product documentation
Resolving licensing issues
Learning with PLAXIS
Via Bentley Communities we offer a lot of learning opportunities live and on-demand.
How to get help
Submit a Support Case for any technical question and support.
Our technical experts are ready to help: https://bentleysystems.service-now.com/csp
Bentley Communities (WIKI and FORUM):
This WIKI and the Forum.
CONNECT Center
https://connect.bentley.com
