Tutorials PLAXIS 3D
This section contains the PLAXIS 3D Tutorials
PLAXIS 3D Tutorial 01: Foundation in overconsolidated clay
workflow
foundation
3D
tags:
PLAXIS 3D Tutorial 02: Excavation in sand
workflow
prestressed ground anchors
prestress
plastic point
ground anchor
excavation
curve
3D
tags:
PLAXIS 3D Tutorial 03: Loading of a suction pile
workflow
undrained
suction pile
suction anchor
shape designer
rigid body
offshore
3D
tags:
PLAXIS 3D Tutorial 04: Stability of a diaphragm wall excavation
retaining wall
diaphragm
d-wall
concrete
bentonite
tags:
PLAXIS 3D Tutorial 05: Phased excavation of a shield tunnel
tunnel lining
tunnel designer
tunnel
shield tunnel
contraction
tags:
PLAXIS 3D Tutorial 06: Construction of a road embankment
safety analysis
embankment
drains
drain
consolidation
change of permeability
tags:
PLAXIS 3D Tutorial 07: Rapid drawdown analysis
unsaturated
time-dependent
fully coupled flow
dam
coupled flow
coupled analysis
tags:
PLAXIS 3D Tutorial 08: Dynamic analysis of a generator on an elastic foundation
rayleigh
generator
foundation
dynamics
dynamic
damping
tags:
PLAXIS 3D Tutorial 09: Free vibration and earthquake analysis of a building
spectrum
small-strain stiffnes
power spectra
natural frequency
hysteretic
free vibration
fast fourier transform
earthquake
dynamics
dynamic
damping
building
tags:
