| Version: | CONNECT, 2023 | ||
| Area: | Configuration | ||
| Subarea: | WorkSpaces |
How can a created WorkSpace or WorkSet be deleted and removed from MicroStation?
When a new WorkSpace or WorkSet is created in MicroStation, a folder and a corresponding .cfg file with the same name will be created.
For example, if you were to create a WorkSpace named Test, a folder named Test and a .cfg file named Test.cfg would be created in the WorkSpaces directory.
To delete the WorkSpace or WorkSet, close MicroStation completely and then delete both the folder and the .cfg file from the file directory.
Below are the default WorkSpaces directories, but keep in mind, these paths can change depending on how you have set up MicroStation's configuration.
MS CONNECTC:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces
MS 2023C:\ProgramData\Bentley\MicroStation 2023\Configuration\WorkSpaces
WorkSets are typically inside WorkSpaces, so the location of the WorkSet folder and .cfg file will vary and usually depend on the location of the WorkSpaces.
For example, the MetroStation WorkSet is contained within the delivered Example WorkSpace
MS CONNECTC:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets
MS 2023C:\ProgramData\Bentley\MicroStation 2023\Configuration\WorkSpaces\Example\WorkSets
Once the WorkSpace or WorkSet folder and .cfg file are deleted, open MicroStation again. The WorkSpace or WorkSet should now be removed from MicroStation.
| Original Author: | Jayson Perry |
