| Version(s): | v8i, CONNECT | ||
| Area: | Raster | ||
| Subarea: | N\A |
A raster file covers the drawn elements in my design file. How can the raster file be put behind the data in the background?
In other words, how do I change the order of placement of the raster file?
Each raster file can be placed individually on one of three different display levels in order to define display sequences:
The following are available: "Background" or "Design" or "Foreground".
Foreground - rasters are on top of all elements
Design - rasters are displayed based on display priority (inherited from used level plus set priority value)
Background - rasters are displayed under all elements
To set the desired raster file to the background layer, click on the layer icon in the row of the raster file in the "Raster Manager" to change the layer. Be sure to press OK and save the changes.
Change Display Order of Raster
| Original Author: | Yvonne Lohse |
