This FAQ is designed to cover the questions regarding running supported MicroStation versions in a certified Virtualized environment.
This can mean a lot of different things and includes many technologies depending on the type of virtualization. MicroStation was tested and certified to run on Citrix XenApp and XenDesktop.
Application Virtualization (http://en.wikipedia.org/wiki/Application_virtualization)
The application is delivered from the server to the client at run-time (when the application is started from the client). The application is not "installed" in the traditional sense, but the application will function as if it was.
The certification process begins with an initial assessment of the software and the Citrix XenApp environment done by the MicroStation certification team. This involves understanding the specific requirements and configurations that are necessary for optimal performance. Key factors considered include the version of Citrix XenApp, the operating system, network requirements, and hardware specifications.
Compatibility testing is conducted to ensure that MicroStation operates correctly within the Citrix XenApp environment. This includes verifying that all features and functionalities of the software are accessible and perform as expected. Any compatibility issues identified during this phase are documented and addressed.
| Supported MicroStation version | MicroStation version # | Virtualized environment compatibility | Resources |
| MicroStation 2026 | 26.00.00.178 | Azure Virtual Desktop (Desktop Client) | Readme |
| MicroStation 2025 | 25.00.001.62 25.00.00.119 |
| MicroStation 2024 | 24.00.02.62 | Citrix XenApp 8.2 and Azure Virtual Desktop (Desktop Client) |
Readme |
| MicroStation 2024 | 24.00.01.56 | Citrix XenApp 8.2 and Azure Virtual Desktop (Desktop Client) |
Readme |
| MicroStation 2024 | 24.00.00.170 | Citrix XenApp 8.2 and Azure Virtual Desktop (Desktop Client) |
Readme |
| MicroStation 2023 | 23.00.02.71 | Citrix XenApp 8.2 and Azure Virtual Desktop (Desktop Client) |
Readme |
| MicroStation 2023 | 23.00.01.44 |
Citrix XenApp 8.2 and |
Readme |
| MicroStation 2023 | 23.00.00.108 | Citrix XenApp 8.2 and Azure Virtual Desktop (Desktop Client) |
Readme |
| MicroStation CONNECT Edition Update 17 | 10.17.02.61 | Citrix XenApp 8.2 | Readme |
The versions of XenApp and MicroStation are also listed in the MicroStation Readme file. Always check the Readme file of your version of MicroStation to see what Citrix version of XenApp it's certified to run on.
For other applications, you may need to check with their responsible parties, to verify their certified environments. Usually, in their ReadMe files, you may find your answer.
No. Only currently supported versions of MicroStation are certified. All other versions and environments are not certified.
Citrix XenApp and Azure Virtual Desktop (Desktop Client) are the applications certified at this time, and the versions will depend upon the MicroStation version. See "What versions of MicroStation are certified in a Virtualized environment" above. However, you should check from time to time for possible additions to certified environments.
This will depend upon the XenApp version. That needed to be defined by who will install Citrix environment in your corporation.
Installing, configuring, and optimizing performance is supported through the providers of the virtualized solution and/or your IT department. Bentley only certifies it's applications to run on their environment
Issues that relate specifically to functionally within the certified environment.
The number of connections is based on the hardware requirements of Citrix. Bentley has no guidance on how many connections can be made.
Anonymous users are not supported per the End User License Agreement. Also, you will need a unique ID for each user that will use MicroStation in your organization.
| Original Author: | Dan Abney |
