| Version(s): | 23.00.xx.xx | ||
| Area: | Open/Save | ||
| Subarea: | Performance |
Some Users may experience slowness or unresponsiveness when launching MicroStation. Here are some common scenarios where users may experience start-up performance issues, as well as some methods for identifying and resolving them.
1. Standard Delivered Configuration
IF you are using a Custom Configuration, switch to Standard Delivered Configuration.
Open ConfigurationSetup.cfg in a Text Editor from following location "C:\ProgramData\Bentley\MicroStation 2023\Configuration\"
Disable or set configuration variable _USTN_CUSTOM_CONFIGURATION, _USTN_USER_CONFIGURATION value to null.
(Example Disable variable loading by adding #):
#_USTN_CUSTOM_CONFIGURATION = E:\My Company\Configuration\
#_USTN_USER_CONFIGURATION = E:\My Company\Configuration\
(Example Set to Null):
Refer Blog
2. Configuration Local or Network
Use a local configuration.
Set configuration variable _USTN_CUSTOM_CONFIGURATION, _USTN_USER_CONFIGURATION value to a local path.
(Example Local Path):
 _USTN_CUSTOM_CONFIGURATION = C:\ProgramData\Bentley\MicroStation 2023\Configuration\
_USTN_USER_CONFIGURATION = C:\ProgramData\Bentley\MicroStation 2023\Configuration\
(Example Network Path):
Refer Wiki
Refer Wiki2 (Network Performance)
3. UPF
UPF location: UPF file on the network can cause significant performance issues.
Ensure configuration variable MS_USERPREF is set to a local location.
e.g., "C:\Users\{UserName}\AppData\Local\Bentley\MicroStation\23.0.0\prefs\Personal.upf"
Corrupt UPF: Backup UPF Or Restore Default settings.
4. Custom or Third-party applications
Turn off autoloading of custom applications.
Ensure the following configuration variables are not set.
MS_INITAPPS
MS_DGNAPPS
MS_VBAAUTOLOADPROJECTS
5. Project Wise Environment
Ensure that the product/version being used is certified by referring to the ProjectWise Version Support Matrix
Disable ProjectWise Integration. Refer Wiki
6. Properties, Explorer Dialog
Reloading the product after closing the Properties, Explorer dialog has improved performance. Refer Wiki
7. Thumbnail Preview
Optimize performance by disabling thumbnail preview. Refer Blog
8. Antivirus
Antivirus software can sometimes impact your computer's performance. You can improve performance by adding exclusions for known files and folders. Refer Wikis
9. Fatal Error. Could not create a .ma file for an Addin
Multiple computers are experiencing sporadic MicroStation failures due to files being deleted from the AddInLoader1.0 folder.
Refer Wiki
10. If Problems Persists
Ideally collect the following, log a Service Case and work with the Support team in troubleshooting the issue.
Performance Troubleshooting Steps
| Original Author: | Leonard Jones |
