| Version(s): | V8i, CONNECT, 2023 | ||
| Area: | Printing | ||
| Subarea: | Driver/PDF |
How to print with Borders
From User…
How can I set the Print Borders to always be ON in all sessions.
Option 1 - Print Dialog Print Attributes
From MicroStation's Print dialog (File > Print > Print) go to Settings > Print Attributes
Turn on Print border and add the comments in the Border comment field box.
Option 3 - Print Key-ins
Following key-in can be used to always start the Print Dialog with Print Border attribute turned ON.
dialog plot; print attributes border on
Key-in can be added to a Function key or a Ribbon button.
Using MicroStation variables in Print border comments
| Original Author: | Leonard Jones |
