Supported Thread-Connected Devices List
Back to Product Wiki
Below is a list of hardware that can be connected to a Thread via digital connect cables and are integrated into the iTwin IoT platform. The Partner Device Registry is also a useful tool for determining which devices and sensors are compatible with the iTwin IoT application and how they can be connected to the platform via available logger options.
Badger M2000 Flowmeter
Badger M5000 Flowmeter
Badger 380 Series BTU Meter
BeadedStream M-Link Connection for Digital Temperature Cable
BeadedStream Recite Connection for Digital Temperature Cable
Call & Nicholas Instruments SlideMinder
Campbell Scientific AVW200 VW Analyzer Module
Campbell Scientific Water Content Reflectometer
Campbell Scientific LevelVUEB10 Bubbler
DSI Dynaforce Elasto-Magnetic Sensor
DGSI M-Logger MEMS Tiltmeter Logger
DGSI MEMS Tiltmeter
DGSI Mini-Logger VW Logger
DGSI V-Logger VW Logger
Euromag MC608 Converter
Flowav PS1000 SDE
Geokon 3810A Thermistor String
Geokon 8002 VW Data Logger
Geokon 8960-01C VW Interface
Geokon MEMS IPI
Geokon Tiltbeam
Geokon Triaxial Mems Tilt
Geolaser AMTS Auto Level
Geosense Smartmux
Geosense Tilt Meter
In-Situ AquaTROLL 200 Data Logger
In-Situ AquaTROLL 500 Data Logger
In-Situ LevelTroll Data Logger
In-Situ RuggedTroll Data Logger
Jewell Instruments Lily Borehole Tiltmeter
Jewell Instruments Tuff Tilt Tiltmeter
Kinemetrics Etna2 Accelerograph
Leica GMX-Series GNSS Antenna
Leica Nivel Inclination Sensor
Leica Total Station
Measurand ShapeArray (Current Models)
Measurand ShapeArray XYZ (Older Models)
Relay Switch Device
Petrosense DHP-485 Digital Hydrocarbon Probe
PT100 RTD
RST Digital In-Place Inclinometer
RST MEMS Digital Tilt Meter
RST Digital Tilt Meter
RST R2T
RST Tunnel Profile Monitoring System
RocTest Fiber Optic Multi-Channel Field Data Logger
RocTest RT-VLOG VW Logger
RocTest RxTx Remote Reading Pendulum Station
Senix ToughSonic Ultrasonic Distance Sensor
Schlumberger Variable Frequency Drive
Schneider ALTIVAR 630 Variable Frequency Drive
Seafloor Systems Sonar Device
Solinst Levelogger Water Level Data Logger
Topcon Robotic Total Station
Turner Designs C3 Fluorometer
Vaisala AQT530 Air Quality Monitoring Station
Vaisala WXT536 Weather Monitoring Station
YSI SensorNet VisoTurb Turbidity Probe
YieldPoint d-Exto Multiple Rod Extensometer
YieldPoint d-MPBX Multiple Point Borehole Extensometer
Senceive Tilt Sensors
Sensemetrics Field Camera
Sensemetrics Multipurpose 4-20 Device
