| Version: | V8i, CONNECT Edition | ||
| Area: | DGN | ||
| Subarea: | Compress |
How can Compress options be turned ON/OFF via Key-in ?
Keyin: compress options on <ALIAS NAME>
The alias names are listed in the Compress Options dialog. A list of these aliases can be found in Compress Options.
Examples:
To turn on the "Delete unused fonts" option:
compress options on FONTS
To turn off the "Delete unused fonts" option:
compress options off FONTS
This command could be useful when running file compression by batch process, for instance, or even running a batch process that requires all compress options to be on:
compress options on ALL
