| Version | PLAXIS 2023 PLAXIS CONNECT Edition |
| Date created | 02 August 2023 |
| Date modified | 02 August 2023 |
PLAXIS enables integration with Bentley Systems' ProjectWise. The PLAXIS - ProjectWise integration is a collaboration and information management solution. This tool establishes a single managed repository and helps in quick and easy information access to all internal and external participants. The users can also manage project information such as changes, audit trails and version histories are automatically tracked and can be referenced at any point in the project.
PLAXIS files can be stored in ProjectWise, and using ProjectWise Explorer, the file can be checked out, opened, edited, and checked back in.
This video covers:
