| Product(s): | MicroStation | |
| Version(s): | N\A | |
| Environment: | N\A | |
| Area: | Graphics Display | |
| Subarea: | General | |
How can I display Construct Class elements in a View with different Symbology, to help distinguish between Primary and Construction elements?
Option 1 Use A Display Rule
- Open the Display Styles dialog
- Create a new Display Style or select an existing one for Edit.
- In the Display Styles dialog select the Display Rules icon next to Display Rules drop-down List, to open the Display Rules dialog.
- Create a new Display Rule Set (or pick existing) and create a new Display Rule
- Select the default Condition 'Always Applies' and in the Condition Editor dialog pick the Property 'Class' (Element>Elements Common Properties>General>Class)
- Select '=' and pick 'Construction' from the drop-down list followed by OK
- Add a new 'Action' and change the 'Symbology Overrides' to those required.
- In the Display Styles dialog select the newly created Display Rule
- Apply the Display Style to the View
Option 2 Use A Dedicated Level
- Open the Level Manager dialog
- Create a new Level 'Construction'
- Set the Construction Levels Symbology:(ByLevel or Overrides)
- Set the Color, Style, Weight as required for the Construction Class elements
- Place or Move all 'Construction Class' elements onto the Level 'Construction'
- Optional: In View Attributes apply 'Level Overrides' if set in steps 3 & 4
Can we define the display Rules in a dgnlib?
Can we apply Display Rules on Clip volumes?
How to change the Attributes of Multiple elements
How to change all elements from Construction Class to Primary Class
Other language sources
| Original Author: | Carl Myhill | |
