Product(s): | MicroStation | ||
Version(s): | 10.15.00.74 | ||
Environment: | N\A | ||
Area: | Installation | ||
Subarea: | Troubleshoot New Installations (Single Users) |
MicroStation CONNECT Edition can be Installed and updated, in several different ways.
The method and version required may depend upon your Organization, so please check with your Site Administrator or IT department before installing.
Methods of Install:
MANUALLY RUNNING EXECUTABLE: An installation from downloaded Software
CONNECTION CLIENT: An installation via the CONNECTION CLIENT if previous Update is already Installed
DEPLOYMENT IMAGE: An Organizations Pre-Configured Application install
PUSHED BY IT: An Organizations IT department may push Pre-Configured Application install
That said at some point the software needs to be acquired, you may have been sent a Fulfillment document with links to download the software when ordering.
The software can also be downloaded from https://connect.bentley.com/ see also these Software Download Instructions
Note also your Site Administrator may have also restricted you from obtaining software through the Software Administration Service so again check with them if the Product is not available to you.
Here are some resources to help you with Downloading MicroStation CONNECT Edition.
Help
Blogs
CONNECT Wikis
How-to-download-and-install-microstation-connect-10-00-00-25-new-portal
Pre CONNECT
How to download MicroStation (Previous Version of Web Downloads)
Bentley-live-player-microstation-connect-free-trial-minimum-requirements
How-to-download-microstation-software-download-page
How to download the Prerequisites for Desktop Application such as MicroStation
Where can I find the Revit Plugin for i-Model?
Cannot download from Fulfillment document
Return to
