How to receive Technical Support
Application All supported Geotechnical applications
Version All supported versions
Date created 12 November 2021
Date modified 8 January 2025
When using any Geotechnical Analysis software (GeoStudio or PLAXIS), our support teams are ready to assist you when you need our help.
To reach the support teams, you can open a Case using our online platform. After that, we will process it and connect you with the support expert to help you further with your request.
You can also navigate to Bentley's Support page for more information.
Cases
You can submit all your support questions via Bentley's Customer Service Portal (ServiceNow).
You can select Open a Case by selecting the relevant option on the main page:
Picture 1. Customer Service Portal overview
You can directly follow the progress of any of your existing Cases by selecting the View My Cases option.
Contact by phone (toll-free number)
If you want to contact Bentley/Seequent support services directly via the phone, in order to solve urgent issues, we are happy to help.
You can find an overview of our contact numbers below:
Note that you can always navigate to the Bentley Cloud Services portal, locate the My Services section at the very bottom and choose Support Contact Information tile from the available options.
If your login profile is associated with an account that has a SELECT contract with Bentley, a web page will appear with the support numbers for several countries.
Picture 2. Support Contact Information tile in Bentley Cloud Services portal
Support Emails
All Bentley support teams communicate via emails from either support@bentley.com for product support issues or bac@bentley.com for licensing and contract issues. Always make sure to either use the Customer Support Portal (ServiceNow) or reply directly to the email without changing any existing lines of the original message to ensure proper routing of your query.
After you opened a new Case, we will send out an email confirmation with the Case ID, which should appear in your email Inbox.
In some cases, we see that these emails do not arrive, mostly because email/spam systems filter out our emails. In these cases, our Case reply probably lands in your spam folder or in a non-priority or Promotion Inbox folder.
For these cases, it is best to check with your IT department to ensure that the Bentley emails (support@bentley.com and bac@bentley.com) are whitelisted.
More information on how to whitelist an email address is included in the article How to whitelist an email address.
Support for Your Software
For more information on the supported versions and license types, you can follow the links below:
Useful links
