This section contains a list of resolved: issues in PLAXIS 2D and PLAXIS 3D. Click on the hyperlinks for more information.
Released: February 2026
The following issues were resolved:
| Solved known issue | Application | Issue # |
| Error 604 in PLAXIS 2D 2025.1.0 for free-field Dynamics analysis with horizontal interface at Ymax | PLAXIS 2D | 1928469 |
| Point loads merging on embedded beams with interfaces lead to incorrect results in PLAXIS 3D | PLAXIS 3D | 1962642 |
| PLAXIS 2024.3 version and older crashes at launch with latest ProjectWise Explorer | PLAXIS 2D PLAXIS 3D |
1983105 |
Released: November 2025
| Error 602 in PLAXIS 3D 2025.1.0 for Safety calculations with beams | PLAXIS 3D | 1927499 |
| Displacement fixities are not applied to isolated beam elements | PLAXIS 3D | 700220 |
| Incorrect display of dynamic boundary condition options in existing PLAXIS projects | PLAXIS 3D | 1694850 |
Released: May 2025
The following issue was resolved:
| Severe divergence error when running a dynamic analysis with custom connections in PLAXIS 3D | PLAXIS 3D | 1394428 |
Released: July 2024
| Error when using unsupported Elastoplastic (M-kappa) embedded beam elements in PLAXIS 3D | PLAXIS 3D | 1347993 |
Released: October 2023
| Error when generating the mesh for embedded beams set to grout body | PLAXIS 3D | 1268947 |
| Groups created in green modes are lost when reloading | PLAXIS 2D PLAXIS 3D |
1268947 |
| Incorrect visualisation of phreatic level in PLAXIS 3D 2023.2 | PLAXIS 3D | 1268947 |
| Dynamic point loads in axisymmetric 2D models do not consider the radius | PLAXIS 2D | 1092643 |
| OpenSSL vulnerability not affecting PLAXIS 2D or PLAXIS 3D | PLAXIS 2D | 1149242 |
Released: February 2023
| Report generator issue with Material information when different material types for plates and anchors used in projects | PLAXIS 2D | 1025141 |
Released: October 2022
| Some Input tables and Output results may not consider project units in PLAXIS CONNECT Edition V22 [V22.01] | PLAXIS 2D PLAXIS 3D |
861673, 989888 |
Released: May 2022
| PLAXIS Design Approach partial factor not applied to material parameters when loading older files | PLAXIS 2D | 629857 |
| PLAXIS Calculation Manager does not save in PLAXIS CONNECT Edition V22.00 | PLAXIS 2D PLAXIS 3D |
791427 |
| Visualisation issue of embedded beam connections in Staged construction in PLAXIS CONNECT Edition V22.00 | PLAXIS 2D PLAXIS 3D |
845837 |
Released: January 2022
| PLAXIS LE importer incorrectly converts geometry when having comma as decimal symbol | PLAXIS 2D | 604677 |
| Deconfinement feature might generate wrong stress distribution for dry conditions | PLAXIS 2D | 669296 |
Released: February 2021
| PLAXIS CONNECT Edition V21.00.00 calculation does not start due to a license issue | PLAXIS 2D PLAXIS 3D |
540768 |
| Tunnel beams/girders generated in the wrong direction | PLAXIS 3D | 499737 |
| Geogrids may trigger a Run-time kernel error [256] | PLAXIS 3D | 473803 |
| PLAXIS 2D meshing stops with error Ordinal 747 not located | PLAXIS 2D | 447463 |
Released: September 2020
| 1D Site Response Analysis does not work in non-English versions | PLAXIS 2D | SW-47784 |
| Deconfinement method gives unexpected results in case of pore water pressure change in PLAXIS 2D | PLAXIS 2D | 379697 |
Released: June 2020
| SciTE issues when running a Python script | PLAXIS 2D PLAXIS 3D |
SW-47996 |
| Objects names with special Unicode characters may fail in meshing | PLAXIS 3D | SW-47115 |
Released: March 2020
| Permeability value change not stored when changing from From data set to None | PLAXIS 2D PLAXIS 3D |
SW-21183 |
| Ignoring suction after a fully coupled flow-deformation analysis in Safety analysis gives incorrect stresses in PLAXIS 2D | PLAXIS 2D | SW-45205 |
Detailed data per specific release for older versions not yet available
