How to Move the Origin of the Cell in the cell library
 Product(s):MicroStation
 Version(s):V8, V8 2004, V8 XM, V8i, CONNECT, 2023
 Environment: N\A
 Area: Cells
 Subarea: General
How to move the origin of a cell in the cell library (.cel file)?
1. Open the Cell Library file that contains the cell. Typically this is .cel file format.
2. Open the Models dialog and choose the Model which you want to modify (double-click or right-click > Open).The name of the Model is also the cell name
3. Key-in: choose all;move extended;/d;xy=0,0,0 & press Enter
4. Select the point on the cell that will become the new origin. Then right-click to reset
How to create cells in Microstation
Locate the cell origin in cell libraries
Other Language Sources
Deutsch
