Product: | MicroStation | ||
Version: | V8i , CONNECT | ||
Environment: | N\A | ||
Area: | Configuration | ||
Subarea: | General |
Can Design History be removed in MicroStation without having to run the packager utility and remove the history using this method?
Under the Utilities > Design History > Delete has been added to remove the design history from a design file.
Set MS_DESIGN_HISTORY to value of delete=1. Save configuration changes, exit, and restart MicroStation. Then use the key-in HISTORY DELETE
Original Author: | Bentley Technical Support Group |
