PLAXIS 2D Tutorial 17: Free vibration and earthquake analysis of a building
Application PLAXIS 2D
Version PLAXIS 2D CONNECT Edition V21.01
PLAXIS 2D 2024.1
PLAXIS 2D 2024.2
Date created 20 May 2017
Date modified 21 August 2024
This example demonstrates the natural frequency of a five-storey building when subjected to free vibration and earthquake loading.
The building consists of 5 floors and a basement. It is 10 m wide and 17 m high including the basement. The total height from the ground level is 5 x 3 m = 15 m and the basement is 2 m deep. A value of 5 kN/m2 is taken as the weight of the floors and the walls. The building is constructed on a clay layer of 15 m depth underlayed by a deep sand layer. In the model, 25 m of the sand layer will be considered.
PLAXIS 2D Tutorial: Earthquake and building
This exercise requires a PLAXIS 2D Ultimate license to access the Dynamics features.
The attached *.log file contains all the commands to generate the model. With a Bentley Geotechnical SELECT Entitlement [GSE] licence, you can use the commands runner to open the *.log file and to execute all commands in one go, see also this instruction.
Downloads
See also
