MicroStation Accessing Files Stored on Cloud-Base Drives
 Product:MicroStation
 Version:CONNECT, 2023
 Environment:N\A
 Area:DGN
 Subarea:General
There are a number of cloud-based storage applications on the market.
These methods of storage are being used to both store and modify files. While it is convenient to edit a drawing file from any location that has an internet connection, opening these cloud files directly from their storage locations have, at times, caused problems with consistency of data in MicroStation and other Bentley products and have even caused these applications to crash.
What is Bentley's recommendation?
MicroStation is enabled to work with cloud-based storage repositories for the exchange of drawing files. ProjectWise 365 / ProjectWise Drive is the preferred (and certified) file exchange service for Bentley desktop products.
There has been some light testing of the following applications but we do not officially “certify” these applications. Bentley Systems is not responsible for any loss of data accessed from these locations.
The following should be used at your own risk:
Bentley does understand that these cloud-based storage repositories are in use by some of our users. However, due to reasons beyond our control, we cannot certify these cloud-based storage repositories in the foreseeable future. Using these cloud-based storage repositories to store or edit files in conjunction with Bentley applications is being done at your risk.
New in MicroStation CONNECT Edition Update 17 – ProjectWise Drive
 FAQ
View this short video "Introduction to ProjectWise Drive."  https://www.youtube.com/watch?v=ZBfFXLXMnGM
Other Language Sources
Español  Français  Deutsch Italiano
 Original Author:Regie Wallace
