Issue Resolution
This page contains multiple dashboards about the data recorded through the "Create Issue" button    in the iModel visualizer. Those  issues can be listed on the iModel Visualizer on the side panel too.
If the dashboard is accessed from the main menu, all the different type of Issues created are shown as different dynamic dashboards.
You can change the view of the other panels by changing a selection in one panel, the filtered value will appear on the top section of the dashboards as below
It is possible to go in detail of each Issue, by clicking the link from list at the bottom of the page, you can make changes, see the attachments, notes or open a visualizer to see the location.
