PLAXIS 2D CE V22.01.00 Release notes
New in PLAXIS 2D CONNECT Edition V22 Update 1
Release: May 2022
PLAXIS 2D CONNECT Edition V22 (22.01.00.452) contains the following improvements and updates compared to PLAXIS 2D CONNECT Edition V22.00:
Compatibility notes: Due to the major changes in the material database and the unit system, PLAXIS 2D CONNECT Edition Version 22 will be installed alongside Version 21, instead of overwriting it. When opening PLAXIS 2D V21 projects with PLAXIS 2D V22, projects will automatically be saved as a converted copy with the _converted suffix and will require recalculation. When using non-SI-units, the mesh also needs to be regenerated.
The PLAXIS 2D CONNECT Edition V21 projects will remain unchanged.
Earlier versions of PLAXIS will not be able to open files saved in PLAXIS 2D V22.
New features
Importing closed polycurves as polygons
Added support for importing closed polycurves as polygons, easing the import of soil layers from CAD files.
Creating polygons from closed polycurves
Added support for creation of polygons from closed polycurves. This can be directly done from the drawing canvas, or via the command line.
Command for retrieving results from cross-sections in Output
Added the getcrosssectionresults command for retrieving results from cross-sections in Output.
Fixed issues
The following known issues have been fixed in this version:
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads.
