Unresolved issues - Overview - PLAXIS
This section contains the updated list of unresolved/open issues in PLAXIS 2D's and PLAXIS 3D's latest releases:
Known issue Application Issue #
Complex plate connections with interfaces may result in unexpected behaviour PLAXIS 2D
PLAXIS 3D
379391 / SW-47400
Tension cut-off for Soft Soil (Creep) and UDSM interfaces PLAXIS 2D
PLAXIS 3D
373161 / SW-15553
Incorrect data for centerline with an offset tunnel PLAXIS 2D 373395 / SW-3760
Limited availability of UDSM State Parameters in Output when using multiple UDSM in one phase PLAXIS 2D  PLAXIS 3D 1985660 / 1987089
Combined elastoplastic and M-k behaviour for embedded beams may result in elastic behaviour PLAXIS 2D 1992746
