| Defect Number | Description |
| 699407 | Improved Cached View Support |
| 707806 | Resolved issues with 2D Rebar representations |
| 785926 | Improved 2D rebar resymbolization |
| 857525 | Improved text scaling in Rebar Labels |
| 861120 | Resolved issues with 2D Rebar update |
| 864266 | Improved arrow terminators in 2D Rebar Labels |
| 884356 | Resolved issues with modeling arc reinforcement using Irregular Dispatch Reinforcing |
| 885093 | Resolved issues with opening reinforcement |
| 885094 | Resolved issues with perimeter trimmer reinforcement |
| 891767 | Improved concrete positioning including reinforcement comparison |
| 891940 | Improved 2D rebar label placement |
| 892110 | Optimized Concrete and Steel ribbon UI |
| 265798 | The dialog visibility and images are enhanced for various connections |
| 275498 | All Solid concrete references are showing up in Imodels |
| 272325 | DIN EN ISO 2553 support for the presentation of welding symbols is implemented |
| 797089 | Fraction stacking settings for imperial weld, elevation and position flags was improved |
| 916716 | Text style for Position Flag is in any cases following the assigned Text Style |
| 941041 | Text styles are now following always the dimension style settings |
| 983845, | The position flag and weld flag appearances were enhanced for various cases |
| 983851, |
| 983855 |
| 796367 | Length, names, and annotations are now fully conforming to the imperial formatting convention |
| 918567 | The construction axis is now always correctly dimensioned |
| 956114 | The Box frame detail is showing position flags of objects now only inside the box frame |
| 923939 | Hidden lines are correctly calculated for objects hidden under curved plates with modifications |
| 743772 | Hidden display classes are now converted from existing DWG´s |
| 907991 | ProStructures object properties are now working with all Display Rule Conditions |
| 948592 | ProStructures properties do work with Display Rules of MicroStation Display Styles |
| 798222 | Access to the section mapping table is available during ISM import. |
| 972972 | Improvements in ISM for curved members |
| 963172 | Converted PS solids to native MS smart solids have now tags attached when saving DGN to DWG |
| 571121 | Numerous improvements to NC export for edge preparation and contours |
| 928787 | Full implementation of Zeman robotic assembler |
| 970727 | Improvements in opening time for ProStructures Series 8 DGN |
| 817242 | The file size and the element amount for detail drawings were significantly reduced |
| 933963 | the handling of Structural Stair elements was enhanced |
| 934545 | The conversion speed DWG to DGN was improved |
| 937859 | The opening speed for DGN´s has improved |
| 1004164 | the copy and move speed for Structural elements Stair was boosted |
| 939841 | Fabtrol List for Group and Group Part List to ProSteel Reporting added |
| 871902, | Various issues in online documentation have been addressed. |
| 939065, |
| 960964 |
| 920681 | Welded shapes can be stretched with grip points or fence stretch |
| 931984 | Flybrace Purlin Beam Connection is now working with welded I Shapes |
| 944333, | Grouping is improved for various connections |
| 944335, |
| 944337 |
| 961531 | Several Connections have been improved in functionality |
| 974174, | The Stiffener Distribution connection is available now and was enhanced |
| 974192, |
| 974755 |
| 1000046 | Work frame views are maintained when copied within the same DGN |
| 973700 | Position Mapping is now available in Preferences |
| 979559 | Long bar label placeholders’ box does accept manually entered input now. |
